Thingworx version : 9.6.1
I am trying to set blinking of red color on thingworx grid based on a value for a particular column value.
I used State definition to achieve the same.
I created style definition using media entity and for media entity I used GIF for image.
But GIF moved to label the to an extent that it became invisible.
I have uploaded GridBlink image which shows red color but it is actually blinking and CSS from developer tools which shows the label inside column when width is reduced to 5%.
But when this css is used directly as custom css, It is not working. Have uploaded css also.
My requirement is to have blinking red color for a grid column and the label value should be appearing while blinking. Kindly suggest me how to achieve this
Maybe CSS animations will work better for you than a GIF background? See https://cargo2support.cargo.site/Make-Something-Blink
Of course, you'll still need to figure out how to apply a custom CSS to a cell.
/ Constantine
I tried but unable to set blink on Grid cells based on condition using css animations. Kindly help me with the code/logic to achieve the same for rendering the blink based on condition over grid cells.
just to let you know that I tried to achieve what you want but also failed. I could not select the grid cells via css selector - as they are hidden in nested dom shadow-root elements which are not exposed.
Check the "Custom CSS" tab. Also I used custom state formatting as selector for the cells (so only cells which have isSystemObject=true currently blink). customize as needed.
(Scrolling in grid causes different timings in css animation for each cell - you might want to look into this :P)
Nice - I learned something!
Hello @KN_13694616 ,
I have also looked for several different approaches to get a CSS blink.
Nothing identified worked.
I would suggest that you post a suggestion on the group for product upgrades.
Peter
