Add Visibility Permission - Thingworx 9.1
Sathishkumar_C
I am trying to add visibility permission programmatically in thingworx 9.1.
Facing following err:
Message :: TypeError: Cannot call method "AddVisibilityPermission" of null
2 REPLIES 2
nmutter
(To:Sathishkumar_C)
This kind of error appears if the object you are trying to AddVisibility to cannot be found. Check if the entity exists you call the service on.
E.g. Things["DoesNotExistInYourInstance"].AddVisibilityPermission(); will fail with the error you experience. But Things["SystemRepository"].AddVisibilityPermission(); will result in an error that parameter is missing.
Hi @Sathishkumar_C ,
It seems like the permission have not applied successfully. You can refer the attached article for your reference.
https://www.ptc.com/en/support/article/CS236180
Feel free to reach out if you still face the issue.
Regards
Bhawna
