AddStreamEntry Not working via REST API
tsharma
Not able to add a stream entry when calling the service via REST API, the service result is success but no entries are being added to the respective stream. Tries using both Administrator & Non-Admin user.Works fine when executed from inside thingworx. Please suggest.
slangley
(To:tsharma)
Hi @tsharma.
Can you provide your Post request?  Are you passing the exact same record each time you test?  If so, it may be overwriting.
--Sharon
