I am creating an application with the .net sdk that will run virtual things in a process. But I would also like to connect some virtual thing at any moment in the process.
Example: I start my application with thing1 and thing2. Then a few hours later I want to add thing3.
How would I be able to do so? Is it possible?
François Lévesque
I think the question is related to the creation of a new instance - in context of the SteamSensor Example - of a new SteamThing in the already running application.
SteamSensorClient client = createClient(host, appKey);
/* (done in createClient call)
// Create two Virtual Things
SteamThing sensor1 = new SteamThing("SteamSensor1", "1st Floor Steam Sensor", null, client);
SteamThing sensor2 = new SteamThing("SteamSensor2", "2nd Floor Steam Sensor", "SN0002", client);
// Bind the Virtual Things
client.bindThing(sensor1);
client.bindThing(sensor2);
// Wait for the SteamSensorClient to connect, then process its associated things.
// As long as the client has not been shutdown, continue
while (!client.isShutdown())
// Only process the Virtual Things if the client is connected
if (client.isConnected())
ThreadPool.QueueUserWorkItem(client.runClient);
// Question: Can we here also create new SteamThings and bind it to the client?
// Suspend processing at the scan rate interval
Thread.Sleep(scanRate);
I did not yet do it like this. I cannot answer this question.
You have a full set of services available that you could invoke after connection. So it is certainly possible to do things like auto create based on a trigger, or 'self-registration' there have been several threads on this, quite a long time ago, hopefully you can find it using a search.
I've been searching all day for a post that would give me what I am looking for and I found nothing. Would it be possible to point me in the right direction please. Since I am new to the sdk and ThingWorx.
Hope these articles, have some content that can help you along.
https://community.ptc.com/t5/ThingWorx-Developers/Create-missing-Things-via-404-s/m-p/771301
https://community.ptc.com/t5/ThingWorx-Developers/how-to-check-if-a-remotething-is-bound/m-p/529896
So I've read the content and I think I did not explain my self clearly. I will try to do so.
I do not need to create things with the sdk.
I need to bindThings after I started a process with some Things in it.
What I've tried to do so is create a Thing that will manage the insertion of other Things.
But when I bind things they do not connect in ThingWorx web platform.
Can I bind things after I have started my process and what do I need to do?
Frank
When you say bind, you are using devices and RemoteThings?
I think your explanation lacks a lot of context unfortunately.
But I would say that if something needs to be bound, as something is in progress, and that process needs the bound items,
you will likely run into a lot of latency/timing issues.
You probably want to carefully outline each step that is being taken and then create some sort of asynchronous approach that allows it to work.
thanks for this answer it was actually what we were about to try.
The real reason it was not working was because I was assigning Identifiers to my things and those remotethings did not have an identifier.
