Wondering if there is a way to add a field in data shape dynamically? Example - In Windchill CAD document, if a new IBA is added. Is there a way to get this attribute added to data shape as a field pragmatically? Today I have to add this new attribute manually into data shape. Same in mashup.
thanks.
Yes it's, I create DataShape's on demand
Load DataShape:
var dataShapeReference = DataShapes["dataShapeName"];
dataShapeReference.AddFieldDefinition({ name: "newFieldName", type: "FIELD_TYPE", ordinal: 9 });
thanks Carles for replying. Have you used CreateDataShape service in PTC-Windchill-Demo-Thing?
No we don't use Windchill / Windchild extension. But CreateDataShape it's not related to WindChild extension it's a standard TW feature.
yes Carles.
My findings so far on this is - we can get IBA information from CreateDataShape service. The IBAs on WIndchill Object needs to be added manually to the data shape. This is not good. It really takes away configurability.
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
