I found the advanced grid doesn't display at all if set the Master for the mashup which hold the advanced grid. If remove the Master from mashup then the advanced grid show up. No application log found . Is this a known problem ?
Version:
ThingWorx 8.4
grid-advanced-4.2.0.zip
Sean
Can you please add a picture or a video?
Also can you please add the XML for both mashup and master?
Hi @ashaban ,
I uploaded the exported Entities.xml in the post.
Master: masterAdvancedGrid
Mashup: TestAdvancedGrid
And I just notice that if refresh the page then the grid can display, but it doesn't display when loading the page the first time.
Sean
Can you please report an issue with the PTC Technical support?
@ashaban ,
the case is opened :
https://support.ptc.com/apps/case_logger_viewer/auth/ssl/case=14836204?from=logger
