Advanced grid right align not working
VK_10159720
7-Bedrock
Hi developers,
I have a requirement to right align data of one column. I am using Thingworx 8. Issue is that even after selecting right align by configuring grid columns, its still not aligning right. Note: that column has state formatting on it to show different colors based on some condition.
I tried to achieve right aligning via custom css but its right aligning entire row horizontally but not column data vertically.
Kindly suggest.
Hello
You can use this links for reference as mentioned below for your problem along with you can user some custom css for alignment.
https://community.ptc.com/t5/ThingWorx-Developers/quot-Advanced-Grid-quot-custom-configuration-by-js...
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Mashup_Builder/...
Thanks and regards,
Rushikesh Shrimal
Hi @S_Rushikesh ,
Thanks for your response. I exported the mashup and edited the css, but only option i could see was align. I changed it from left to right, but it didn't work. Data is still coming left aligned.
Also, as i had already mentioned in the post that Custom css can not be used as its right aligning entire row horizontally but not all data of one column vertically.
Kindly suggest
Hello VK_10159720,
Thank you for your response. I read some articles of ThingWorx help and provided links for your reference.
I hope these will help.
Advanced Grids Samples File
Thanks and regards,
Rushikesh Shrimal
