There are few alerts in the alert summary stream which are triggered by some thing in thingworx ,but when i try to acknowledge those alerts either through the mashup provided by thingworx or through a service provided by thingworx i get a success message as the alert has been acknowledged but the alert still remains in the alert summary stream and shows under unacknowledged tab any idea what might be wrong?.urgent help is required.
Hi @sayeedulla @hgrewal.
ThingWorx 8.5, which contains the fix for this issue, was released last Thursday, September 26. I am, therefore, marking this reply as the Accepted Solution.
Thank you for your patience as well as your contribution to the community!
Regards.
--Sharon
Thingworx version 8.3.2
Was any progress made on this issue. Facing the same issue.
I did not get a proper reason for this issue ,yah but the hot fix is that restart your thingworx foundation server
Have you checked to be sure this is not a permissions issue? Do you see the same behavior when using the Administrator account? Can you try under a different browser to see if the behavior is the same?
Regards.
--Sharon
in addition to above, yes I am operating under the Admin account.
Hi everyone.
We discovered this issue has already been reported to R&D. At this time, we do not have a fix release or timeline.
Regards.
--Sharon
The scenario in which alerts are not getting acknowledged has been addressed in the upcoming release due out soon. Once that release is made available, I will let you know.
Regards.
--Sharon
Regards.
--Sharon
