Hi All,
I started a 30-day trial for the Thingworx Evaluation Server with following details .
I started following the Predictive Model guide to create my own analytics. But when configuring the analytics builder via setting, the Analytics gateway list comes empty no matter what I do.
On searching the community, I found very few results on this issue but the only one I found said to ensure these things:
1) Configuration Service hasn't been run ->
2) Session Variables haven't been added ->
3) The Application Key expiration-date hasn't been extended -> .
Also, there's no AnalyticsServer_Thing also.
I don't know what else to do as I'm new to this field and I'm stuck at this point.
Ashutosh,
It looks like the Analytics Server failed to install correctly when your server was created. We deleted the server and reset your account. Please provision a new server when you log back into the Developer Portal. Let us know if you continue to have any issues.
Jeff
Ashutosh,
Jeff
Things have started working now.
