Hi!
I'm pretty new to using ThingWorx, especially the Analytics Builder, and was wondering if I could perform a simple linear regression on a data set I have and somehow return/export the resulting equation of best fit.
Essentially this is just proof of concept that I can input raw data into Analytics, get a model in return, and then apply that model to the external environment I have created- is this a good use case of ThingWorx?
Thanks!
Thank you for posting your question to the PTC Community.
Regarding seeing Linear Regression, building a basic model will provide this information for you under Models > View
In regards to exporting, ThingWorx Analytics can only export the PMML for the model at this time.
Also, I can recommend our Knowledge Article - Getting Started With ThingWorx Analytics, which also has links to other useful articles and videos.
Please let me know if this answers your question by marking this reply as "Solution Accepted"
Neel
Neel
