Hello all,
I have created a predictive model with a binary goal variable (true/ false). Further I have created a mashup where the predicted results are illustrated. Now I want to implement automated notifications. But the notification should be only send to a person, if a trend in the predictions is recognizable (for example, according to the rule: if a "1" is predicted 20 times in a row, an automatic message should be sent to person X).
I have two questions:
1. Is it possible to create automated notifications? If so, how I can I implement them?
2. Is it possible to create automated notification based on some rules (as I mentioned above)?
Thank you already in advance.
Best regards
David
Hi David,
Yes automated notifications can be sent from ThingWorx Platform to user, steps to do so can be found here. I also believe that you should be able to use the rules you listed above to create the notification.
John
Hi David,
John
Hi John,
I have followed the steps you refered to. But I am not sure how I can send notifications based on a rule like for example: "If the model predicts ten times in a row a "1", send a notification to a specific person".
Do you have an idea how I can realize something like that?
