Analytics Things stopped connecting after IP address of the VM changed
SajidPatel
8-Gravel
I have Thingworx platform and Thingworx Analytics installed in a CentOS VM on my laptop. It was working fine until, the IP address of the VM changed (or so I suspect, may be something else also might have affected this).
Please see the attached snapshots - all configurations are with localhost. I haven't used any IP addresses while configuring the Analytics and everything is on the same VM. Is there a way to get edge logs to see whats the error? I do not see anything useful in the Thingworx logs or Analytics logs.
Thanks for your time @cmorfin
Due to these investigations, I was able to find the root cause of the issue. The Java JRE path was hardcoded with specific Java JRE version. It was updated when I installed some other component on the VM as a result breaking the services. I have updated the services and it is working fine now.
Thanks!
8 REPLIES 8
cmorfin
(To:SajidPatel)
Hi @SajidPatel
From the properties file it appears that ThingWorx Analytics connect to ThingWorx using the hostname centos7.
Given that this is a VM I am guessing this is a local name resolution via /etc/hosts file.
So maybe the ip settings in /etc/hosts for this hostname is not up to date anymore.
You can try ping centos7 in a terminal to check if it responds.
Regarding log files, those depends on the version of ThingWorx Analytics used, the article https://www.ptc.com/en/support/article?n=CS268761 will tell you where to find them based on the version.
Hope this helps
Kind regards
Christophe
@cmorfin Thanks for responding
 centos7 is the localhost. ping works fine, please see the attached screenshot.
cmorfin
(To:SajidPatel)
Hi @SajidPatel
Can you specify the version of ThingWorx Analytics you are using and can you upload all the logs from <ThingWorxAnalytics>/data/logs folder ?
Christophe
Please find the logs attached.
I have ThingWorx 8.3.4-b993
& ThingWorx Analytics Manager Framework 8.3.3 b1036
& Thingworx Analytics Server 8.3.3 (Linux - CentOS)
cmorfin
(To:SajidPatel)
Hi @SajidPatel
Thank you for this.
The logs do not shed any light so far.
Could you please do the following:
- execute <ThingWorxAnalytics>/bin/twas.sh stop
- confirm that no ThingWorx Analytics Server processes are running with ps -ef | grep java
if some orphan processes remain, simply kill them
- delete the content of <ThingWorxAnalytics>/data/logs
- restart the server:  <ThingWorxAnalytics>/bin/twas.sh start
- wait 5 min
- if the AnalyticsGateway thing is not connected in Composer after this time, do the following
- execute  <ThingWorxAnalytics>/bin/twas.sh status > /tmp/twaStatus.txt
Send me :
- the /tmp/twaStatus.txt
- a zip of <ThingWorxAnalytics>/data/logs
- a zip of <ThingWorxAnalytics>/config
Thank you
Kind regards
Christophe
@cmorfin
Please find attached logs.zip - it includes all that you asked for + zookeeper.out. There were no log files generated in data log. Also included the yml files where I attempted to bump up the logging verbosity.
The twas status was this:
[root@centos7 bin]# ./twas.sh status
ThingWorx Analytics Server (TWAS) Service is not running ...
Thanks!
slangley
23-Emerald II
(To:SajidPatel)
Hi @SajidPatel.
Since you found the solution, please mark your last post as the Accepted Solution for the benefit of others with the same issue.
--Sharon
