After a fresh install of Apache Tomcat 8.5.50, there are settings in the Tomcat Configuration dialog box for Java 9 Options (see below). Is it best to clear these out, or should these default values be left in?
Hi @bmehringer.
You should leave the defaults but add the additional settings needed for ThingWorx. Please refer to this page from the Help Center with the details.
--Sharon
Hi @bmehringer.
--Sharon
