Could not find the arbortext connector (both connector and extension) in PTC market place. Please share the location of PTC Arbortext Content Delivery Connector compatible with ThingWorx 9.3.x
Hi @dc.
I reached out to the Arbortext team for guidance and they recommended this document in the Arbortext Help Center:
Embedding PTC Arbortext Content Delivery into Cross-Domain Applications
It appears there may be other content that could also be helpful in the Arbortext Help Center.
--Sharon
Hi @Surya_Tiwari , As per the document "Connector Guide", looks like PTC Arbortext Content Delivery Connector is supported upto ThingWorx 8.3. We do not have an option to integrate PTC Arbortext Content Delivery to ThingWorx. Is there any other integration approach or REST APIs to view, edit the document available in Arbortext content Delivery from ThingWorx 9.3+
Can we still refer to the REST API in below URL as per https://www.ptc.com/en/support/article/CS323516
https://support.ptc.com/help/servigistics/en/enunciate/index.html
Hi @dc.
--Sharon
Thanks @slangley, We try this out. But curious to understand if there any other recommended approach to view, edit, publish documents in Arbortext from ThingWorx.
Hi @dc
If your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others in the community.
--Sharon
