Arduino REST call Example ThingWorx
Highlighted
Newbie
This document contains an example of calling the service and receiving a result using the REST ThingWorx. Example Arduino sketch in C language.
#include <SPI.h>
#include <Ethernet.h>
#include <ArduinoJson.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0x03};
char server[] = "tvsn.cloud.thingworx.com";
EthernetClient client;
//ThingWorx App key which replaces login credentials)
char appKey[] = "b0b54023-3977-4670-8a0a-671ef412fe30";
// ThingWorx Thing name for which you want to set properties values
char thingName[] = "ExamleThing";
//Interval of time at which you want the properties values to be sent to TWX server
int timeBetweenRefresh = 5000;
// ThingWorx service that will set values for the properties you need
// See the documentation for this tutorial for more information
char serviceName[] = "ExampleService";
//How many values you will be pushing to ThingWorx
#define propertyCount 2
//Initialize Properties Names and Values Arrays
const char* propertyNames[] = {"Example1", "Example2"};
double propertyValues[propertyCount];
// last time you connected to the server, in milliseconds
unsigned long lastConnectionTime = 0;
// timer waiting for the arrival of characters from the server
unsigned long timer_iot_timeout = 0;
// Receive buffer size
#define BUFF_LENGTH 64
void setup() {
  //shut down the SD Card pins
  pinMode(4, OUTPUT);
  digitalWrite(4, HIGH);
  // start serial port:
  Serial.begin(9600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection:
  Serial.println("Trying to get an IP address using DHCP");
  Ethernet.begin(mac);
  Serial.print("My IP address: ");
  Serial.print(Ethernet.localIP());
  Serial.println();
void loop() {
  // wait the established interval of time before
  // reading values from the sensor
  // and sending them to the TWX server again
  // delay(timeBetweenRefresh);
  if (millis() - lastConnectionTime > timeBetweenRefresh)
    updateServiceValues();
  else
    updateSensorsData();
void updateSensorsData()
  // Aquire sensor values
  propertyValues[0] = 0;
void updateServiceValues()
  // Connection to server Thingworx
  Serial.println("Connecting to IoT server...");
  if (client.connect(server, 80))
    // Check connection
    if (client.connected())
      // Sending a header of a network packet
      Serial.println("Sending data to IoT server...\n");
      Serial.print("POST /Thingworx/Things/");
      client.print("POST /Thingworx/Things/");
      Serial.print(thingName);
      client.print(thingName);
      Serial.print("/Services/");
      client.print("/Services/");
      Serial.print(serviceName);
      client.print(serviceName);
      Serial.print("?appKey=");
      client.print("?appKey=");
      Serial.print(appKey);
      client.print(appKey);
      Serial.print("&method=post&x-thingworx-session=true");
      client.print("&method=post&x-thingworx-session=true");
      // Sending data from sensors
      for (int idx = 0; idx < propertyCount; idx ++)
        Serial.print("&");
        client.print("&");
        Serial.print(propertyNames[idx]);
        client.print(propertyNames[idx]);
        Serial.print("=");
        client.print("=");
        Serial.print(propertyValues[idx]);
        client.print(propertyValues[idx]);
      // Close package
      Serial.println(" HTTP/1.1");
      client.println(" HTTP/1.1");
      Serial.println("Accept: application/json");
      client.println("Accept: application/json");
      Serial.print("Host: ");
      client.print("Host: ");
      Serial.println(server);
      client.println(server);
      Serial.println("Content-Type: application/json");
      client.println("Content-Type: application/json");
      Serial.println();
      client.println();
      // Waiting for a response from the server
      timer_iot_timeout = millis();
      while ((client.available() == 0) && (millis() < timer_iot_timeout + 5000));
      // Display the response on the server, and if a slow connection, wait for the timeout
      char buff[BUFF_LENGTH] = "";
      int iii = 0;
      bool flagJSON = false;
      while ((millis() < timer_iot_timeout + 100) && (client.connected()))
        while (client.available() > 0)
          char symb = client.read();
          Serial.print(symb);
          if (symb == '{')
            flagJSON = true;
          else if (symb == '}')
            flagJSON = false;
          if (flagJSON == true)
            buff[iii] = symb;
            iii ++;
      buff[iii] = '}';
      buff[iii + 1] = '\0';
      Serial.println(buff);
      // Close connection
      client.stop();
      // Decrypted parameters
      StaticJsonBuffer<BUFF_LENGTH> jsonBuffer;
      JsonObject& json_array = jsonBuffer.parseObject(buff);
      //Service result variable (return JSON)
      int result = json_array["result"];
      Serial.println("Result state:   " + String(result));
      Serial.println();
      // Device control
      //controlDevices();
      Serial.println("Packet successfully sent!");
      Serial.println();
      lastConnectionTime = millis();
  else {
    // if you didn't get a connection to the server:
    Serial.println("Connection could not be established");
    client.stop();
Many thanks to the company MGBOT for the idea of this example.
Tags (2)
3 REPLIES 3
Highlighted
Re: Arduino REST call Example ThingWorx
Thank you a lot, this is working as expected for a HTTP Thingworx server..
I want to call  a service on my HTTPS based Thingworx server
https://abc.pp.vuforia.io
How should I modify the code on this specific parts (should I use port 443 ?)
  1. char server[] = "tvsn.cloud.thingworx.com"
  2. if (client.connect(server, 80))
Thanks a lot in advance for your help
Highlighted
Does anyone have problems with this example too?
On the Serial Monitor appears "Packet succesfully sent!" but I do not see anything (New Property Values/Logs) on Thingworx
Thanks for Sharing,
This is a nice example, I do have some questions that you (or anybody) may be able to help with.
1. Why would you use a service to update parameter values?
2. Do you have an example of how to update the parameter values without using a service? I used this as a start and have tried multiple methods with no success. I get a http/1.1 200 response in the serial monitor but the values are not updating.
Thanks in advance.
Bryan
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
