Hi All,
Is it possible to assign visibility permissions at object level in Thingworx? I mean, to each individual mashup/thing/thing template etc.?
Also, can we delete run time permissions which are already there to each individual mashup/thing/thing template etc.?
Appreciate your responses in this regard as soon as possible.
Thanks in advance.Developer Community@
Yes you can define Visibility at object level.
Yes you can delete run time permissions which are already there.
Hi Indira Salem,
As Carles mentioned; its possible.
Refer to following link for more details: Visibility in Organizations
Ankit Gupta
Thanks for your responses Carles and Ankit. But I want those permissions to be assigned and deleted using services. I mean can you please share me the code for assigning visibility permissions at object level and deleting the already existing run time permissions at object level?
Thanks in advance.
You should look at Code Snippets or "Me" section on Mashup Thing / ThingShape/ ThingTemplate service code editor, services like:
