Assing a datashape to a QueryPropertyHistory infotable
jserrano
I have a service that executes the QueryPropertyHistory of a thing. When trying to bind the result data to a grid, or even trying to access the data inside the service, it just wont work.
Does anybody knows how to relate a DataShape to the infoTable resultant of the QueryPropertyHistory service?
More details about the mode:
  • The service is modeled in a Thing Template
  • When the service that uses the QueryPropertyHistory service is executed within a Thing implementhing that Thing Template, it works fine and data is retrived.
  • When the service is executed in a mashup, there is are no properties to pick from the All Data section. I suppose that a DataShape is needed in order to reach the property fields.
ankigupta
(To:jserrano)
Hi Josue Serrano​,
If I understand your property clearly; you can create a custom service and call QueryPropertyHistory service in it and assign the datashape for Infotable as output as per your requirement.
Ankit Gupta
How should I perform assigning the QueryPropertyHistory results to a DataShape of my choice? If I use the "QueryPropertyHistory" snippet under "Me" I assume I get an Infotable that has "undefined" as the DataShape:
// result: INFOTABLE dataShape: "undefined"
var result = me.QueryPropertyHistory(params);
-Risto
Aanjan
(To:rvaaraniemi)
Risto, you don't have to set a DataShape. What you can do instead is, after binding 'All Data' to your Grid widget, check 'ShowAllColumns' and then view your Mashup.
jgorsline
(To:jserrano)
Josue,
Any update on this? Was Ankit Gupta's post helpful? If so, could you click on the "correct answer" or "mark as helpful" button and let us know?
