Originally using ThingWorx 6.0 (6.0.3), we added verification of user credentials against AD by creating and using a custom Directory Service. I believe that we received a Directory Service provided by PTC, but it was customized probably for SSL communication to AD. We upgraded to ThingWorx 6.5, and this custom Directory Service no longer imports. This error appears in the Application Log:
(see error log details) [context: An unexpected server error occurred: com.ge.ip.bms.quality.authenticators.directoryservices.LDAPDirectoryService.updateConfigurationTableStructure()V][message: com.ge.ip.bms.quality.authenticators.directoryservices.LDAPDirectoryService.updateConfigurationTableStructure()V]
In 6.5, is there a better approach to this? is there a supported Directory Service or authenticator that does authentication with AD over SSL? If not, what is necessary to upgrade the custom Directory Service? I believe it probably needs to be compiled against a newer version of the SDK. Are there any other known changes that would be needed?
Ting
This should still be supported, please log a case with support.ptc.com
In ThingWorx 6.5, the call to updateConfigurationTableStructure() was failing (which was working in ThingWorx 6.0).
We moved the configuration table out of the Java code and into metadata.xml and got it working again in ThingWorx 6.5.
You probably need to update your Extension building framework to the 6.5 SDK and that call should still work.
