Auto increment ID key Datatable from Mashup
  • November 20, 2024
  • 3 replies
  • 3900 views
I want to add information from Mashup and I want to have an ID incremental from Mashup that is start from 1.
I try to find something but anything use some service. I have some services already and I don't want to do this incremental from service, I want to do it from Mashup.
Thank you.
Best answer by tenegabi
I made a service separate that add automatically the number.
The service is only call in Mashup and don't need another specifies connexions except Clicked button trigger and Loaded Trigger from Mashup.
try{
    var dtValues= Things["AuditItBOS_Schedule"].GetDataTableEntries({
maxItems: 99999 /* NUMBER {"defaultValue":500} */
    var dtMaxParams = {
            t: dtValues, // INFOTABLE
            columns: "ID", // STRING
            aggregates: "MAX", // STRING
            groupByColumns: undefined // STRING
        var dtMax = parseInt(Resources["InfoTableFunctions"].Aggregate(dtMaxParams).MAX_ID); //INFOTABLE
catch(err){
    result = "Service call error ["+me.name + "]: on line " + err.lineNumber + ". Error Name: " + err.name + ". Error Message: " + err.message;
var result = dtMax+1;
@tenegabi  WIll GUID work for your requirement ?
tenegabi12-AmethystAuthor
Hello @Bikash_Panda ,
I don't know what to tell you, I have try already but it create this type of input: 9beb3c03-0af8-4642-82fa-1114dda72e10
I want to create only number and start from 1, it is simple to identify by users and by me.
Thank you for the answer
I have expected to have already by default in Mashup.
I don't want to use the service because in Mashup, even if are more than 1 user already when the button is pressed ( for add new row ) can have a trigger that bring last ID number and add next one. Like GUID, but I want to know the numbers because I want to make another service that delete the data from Datatable if I have more than 100000 registration.
Thank you.
Hi Tenegabi.
I'm guessing the data will go in a DataTable entity? If that's the case I'm not sure what the best way would be, What I would do is on the Add service's Thing, I would put a property (like LastCreatedId) of type number and persistent, add every time the service adds a record I would look at that value and add 1. But I'm not sure it would be robust against odd scenarios, like concurrency.
If the data is stored in a database, there's a much easier way to do it. You can give the Identity setting to a column, this will do it automatically for you. Here's how you can set it with the wizard in MSSQL :
tenegabi12-AmethystAuthorAnswer
try{
    var dtMaxParams = {
catch(err){
If you want to adopt this approach, i woudl suggest query the data table, sorted by timestamp desc, and only query 1 row, rather then querying 9999 rows. That is performance intensive and also will not work if you have 100000+ rows.
I am not sure of but also check what happens when multiple users do the same operation, same time,
The Thingworx work in a way first come first serv and this think can't happen in theory.
And this case must not happen.
For case that you thing I will have more than 100000 rows I make another service that is erase information older than 6 months and in an month create only 2-3 thousands rows, so it's everything is all right.
