Automatic Backup Data and Entities
effpt3
How to create Automatic Backup to thingworx entites and data instead of exporting into xml or twx files using export option in composer.
I have ThingworxBackupStorage folder in my c drive, but it empty, there are no backup files. Is there anything to be added in platform settings file or do I need to enable any option in composer or do I need to run a service. Please suggest me right approach.
PaiChung
22-Sapphire I
(To:effpt3)
Please see the following resource: SourceControlFunctions
Following services
ExportSourceControlledEntities
ExportSourceControlledEntitiesToZipFile
ImportSourceControlledEntities
4 REPLIES 4
slangley
23-Emerald II
(To:effpt3)
Hi @effpt3.
The ThingworxBackupStorage folder is only used with the H2 database, so if you are running PostgreSQL or SQL Server, it is expected to be empty.
To back up your system to ensure successful recovery in case of issues, please review this article and listen to the video.
If you have further questions, please let us know.
--Sharon
PaiChung
22-Sapphire I
(To:effpt3)
At this time there isn't an automatic backup feature.
You can either
use one of the REST API calls (or services) to do the backup either triggered external or internal using a scheduler
or you can rely on the persistence provider backup
Personally I would recommend always to have database (persistence provider) backup running
But also to add an automated export to Control Source entities, which will allow for the restore of an individual entity.
effpt3
(To:PaiChung)
Hi @PaiChung
How can I do that backup using API call or service.
Which service I need to run?
PaiChung
22-Sapphire I
(To:effpt3)
Following services
