Automatically Import/Export entities from one dev to qa/pro
MM_9023322
Hi all,
I want to get rid of manual import/export from dev to qa/pro. Is there any way by which I can complete these kind of migration automatically?
Thank you!!
BABA-SHYAM
(To:MM_9023322)
HI,
You can use a scheduler to execute the functionality of export which is part of entity service I believe, if two server are on same network, in URL you can mention the path where to set the export file.
Regards
Shyam
MM_9023322
(To:BABA-SHYAM)
Hello Shyam,
Thank you for your response. Using scheduler will not help me, as I am not importing the entities at fixed interval.
Thank you!!
BABA-SHYAM
(To:MM_9023322)
Then just need rest services to call export functionality. Thats it.
slangley
23-Emerald II
(To:MM_9023322)
Hi @MM_9023322.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
