Hi all,
I'm trying to configure SSO for Thingworx, I followed this link, I got stuck at 'Browser SSO' configuration. (PFB PNG for reference)
Could any one help me with this.
Thanks in advance
/VR
Steps to create a self-signed Application Layer certificate for PingFederate
When you visit this tab for the first time, there will be no certificate in the dropdown list. You can import the public part of the Thingworx signing certificate and choose it as Signature Verification Certificate
Follow these steps:
Example: http://<hostname>:8080
Hope it helps,
Raluca Edu
Hi @raluca_edu
Thanks for your response.
I followed your procedure, I have imported federation.xml file from Azure AD. While configuring, I got stuck in this page.
/VR
Click Configure User-Session Creation and set it up.
After that configuration, always click next and you will be guided in the next step in PingFederate.
Best regards,
Raluca Edu
Hi @raluca_edu
Is there any document which cover complete setup process. Because I'm new to SSO configuration, I feel very difficult to configure SSO.
Again I got stuck in this page,
/VR
For documentation, please check PTC Single Sign-on Architecture and Configuration Overview Guide: https://www.ptc.com/support/-/media/FF578D3876DE4C12ABB1E3EB4E1DA191.pdf?sc_lang=en
and this article: https://www.ptc.com/en/support/article/CS271789
Hope it helps,
Raluca Edu
Hi @Velkumar.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
