Azure SQL + Thingworx 8 the performance is low! Help!
gbrentegani
7-Bedrock
Hi  everyone,
I want to discuss the performance about the configuration below:
  • Azure Sql database : S0 standard 10 DTU
  • Azure Virtual machine: Basic A4 (8 vcpus, 14 GB memory)
I noticed a lower performance, for example, get the things entities, than the Local MSQL database.
When I click on Things, Thingworx give me back all the things:
the response is very different here is the result:
1) Thingworx 8 + Azure Sql   (very slow!!!!)    (5715 ms )
2) Thingworx 8 + Local MSQL  (157 ms !!)
I belive that exist a solution to increase performance ..Do you have any suggestion?
I found the solution:
My Azure Virtual machine was in North Europe location
My Azure Sql DB was in West Europe
So I moved the azure SQL DB to North Europe and now the performance is great!!!!
Bye
Bye
