trying to connect azure to thingworx but in 6 and 7 step is needed to configure for following link?
and other think want to ask i have one server of thingworx compser which is installed on different machine so for enviroment path need to configure in my local machine or need to configure in remote machine?
Hello @VS_10112707 ,
Please find the attached file. It is a step by step guide which explains everything in detail.
Regards
Bhawna
Regards
Bhawna
Hi Bhawna,
Thank you for sharing this document!
Hello I am trying azure to thingworx your give documentation and in step 7 i am not able to encrypt file
security {
secret-provider = "com.thingworx.security.provider.keystore.KeyStoreProvider"
default-encryption-key-length = 256
keystore {
password-file-path = "C:\\Program Files (x86)\\ThingWorxFoundation"
password-file-name = "keystore-password"
path = "C:\\Program Files (x86)\\ThingWorxFoundation\\ThingworxStorage"
name = "keystore"
this is my installation of thingworx while entering this command Init encryption.conf getting this Error
intializing from encryption.conf, Failed to create SecurityManager, Failed to load SecretProvider
can you help me out if possible
security {
keystore {
name = "keystore"
Loading config C:\\Program from classpath
Error intializing from C:\\Program, C:\\Program: No configuration setting found for key 'security'
also getting this error while using init encryption.conf
While work on step 8 follow the step as following
create temp folder where security management tool file
then open cmd and enter following command
getting this error
Encryption key C:\\Program not found thingworx
encryptFile C:\\Program Files (x86)\\ThingWorxFoundation\\MED-61183-CD-093_F000_ThingWorx-Azure-IoT-Hub-Connector-4-2-0-5\\Thingworx-Azure-IoT-Hub-Connector-4.2.0.5\\connector\\conf\\azure-iot.conf C:\\Program Files (x86)\\ThingWorxFoundation\\MED-61183-CD-093_F000_ThingWorx-Azure-IoT-Hub-Connector-4-2-0-5\\Thingworx-Azure-IoT-Hub-Connector-4.2.0.5\\connector\\conf\\azure-iot.conf.encrypted
