I have a case where there are two buttons (button1 & button2) and when I click on button1 4 more buttons should be visible and when I click on button2 the buttons that appeared while clicking button1 should be invisible and new set of buttons for button2 should be visible. It is vice versa. How can I achieve this functionality?
Please provide some ideas.
Shalini V.
You may try looking into the Event Router widget, or Validator/Expression widgets (functions in 8.4)
Just wondering if the issue was ever resolved and whether the above answer was helpful. If so, could you please update this thread with the resolution or mark the answer as helpful? Thank you.
