Hi there,
I would like to use a normal thingworx button widget as a back button. This is for design reasons, because in a normal button, you can insert a custom icon.
Unfortunately JS history.back() does not work in an expression. Does anyone know a way to do this without the back button widgets?
Case no:
In the back button widget is theoretically included in icon. However, this is white for me and I also do not get it visible. Does anyone know the parameter that sets the icon color?
Thanks alot!
Hello @cjjaeckson ,
I assume you can use custom CSS to resolve the issue. pls follow the article on creating Custom CSS:
https://www.ptc.com/en/support/article/CS201191
Regards
Bhawna
yes, I know the back button widget. But in that widget it is not possible to change the icon. Furthermore, I didn't find a parameter to change the color of the default icon. In my case I have a white icon with white background at the moment. You can imagine, that it is not visible.
Thanks for you help, but I thing my problem is a little bit more complex.
Anybody can help? Thanks!
At the end, I want a back button that looks like this:
Hello @cjjaeckson ,
Regards
Bhawna
