Is it possible to dynamically color the chart based on the range?
For each range, we need different colors to get displayed in the chart. I have attached the reference. Please help us understand how we can achieve this.
Shalini V.
Hi @svisveswaraiya.
We don't know of a way to do this dynamically. If you're using a static mashup, you might be able to set the ranges manually.
--Sharon
Hi @svisveswaraiya.
--Sharon
If you feel your question has been answered, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
