Bar Graph - Reference Line
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
According to this https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Mashup_Builder/Widgets/AddingReferenceLinesToAChart.html# I can add a reference line to a Bar Chart. I do not see this property on my bar graph widget:
- Labels:
Design
Mashup-Widget
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @LP_10027711.
Yes, reference lines were added in 9.2--see the 9.2 What's New page. Backporting an extension isn't supported.
Regards.
--Sharon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @LP_10027711.
You first have to indicate the number of reference lines in the NumberofReferenceLines property--it defaults to 0. Then the reference line properties will appear.
Regards.
--Sharon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I have Thingworx v 9.1, according to this i need v 9.2. please confirm that is the case? if so, is there a way to just update the widget extension?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @LP_10027711.
Regards.
--Sharon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
thank you! is it an update upgrade to go from 9.1. to 9.2? what documentation can i use?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @LP_10027711.
If you're considering an upgrade, I recommend moving to the latest release of 9.3.1. The documentation for upgrading can be found here:
When performing an upgrade, best practices dictate the following steps occur prior to upgrade to ensure recovery if issues occur:
- Shut down ThingWorx
- Create a snapshot of the app server
- Create a db export
- Restart ThingWorx
- Update a non-prod environment prior to upgrading prod. If possible refresh the non-prod environment with prod data
- Perform a regression test following the non-prod upgrade to identify any changes needed as a result of the upgrade
- Document all steps and determine timings
Regards.
--Sharon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi sharon. i am going to run through the upgrade from 9.1 to 9.3 today. wish me luck! thanks for the info
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Good luck!
--Sharon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
i failed completely! I had to revert to v9.1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @LP_10027711.
What errors did you receive? Do you still have the failure logs that I can take a look at? Refer to this page for locating the logs.
Regards.
--Sharon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
i created a post for it and no one replied so I did not get it upgraded.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
