Best approach to have checkbox with name in a tree hierarchy only for the child elements
  • November 12, 2021
  • 2 replies
  • 3377 views
Hello ,
I have a data source with parent child relation.
Eg:
Fruits
      True,Orange
      False,Apple
Vegetables
      False,Potato
      False,Tomato
I should allow the user to select few fruits and few vegetables. What would be the best approach to achieve it.
I tried with Advanced Tree Grid but i could not get the checkbox to be in the first column from the positioning in the settings.
1. What can i do to get the check box appear in the first column.
2. If there is any better approach with other available widgets.
Thingworx version 9.1.5
Community Manager
November 19, 2021
Hi @sbt.
You could try using the List widget and turn on multiselect in the properties.  If there's more to the use case that needs to be considered, please provide some additional detail.
--Sharon
Community Manager
November 19, 2021
Hi @sbt.
Our suggestion was assuming you would have multiple lists for each grouping, but it may depend on the number of groupings.
What do you intend to do with the selections?
--Sharon
Community Manager
December 2, 2021
Hi @sbt.
Basically, you need to add a list widget for each group.  Be sure to set the MultiSelect option in the properties panel.
--Sharon
I'm not aware that you can prevent the user to select some entries and some not. Do you really need a checkbox?
Normaly we just use the "selected style" to mark that the user selected an entry:
For sure he can also select "Fruit" but this we have to filter in our service.
