I have a requirement to bind Downtime Data Table to a Pareto Chart to analyze the Downtime Category. But the values of duration and cumulative line are not get aggregated to a single Downtime Category. I have attached the screenshots for the same where the bar chart values are individual entries and the cumulative line is not sequential for the same category. Kindly guide me to achieving the requirement.
First of all let me shamelessly plug the fact that PTC ThingWorx now has two great apps for this type of use case, RTPPM and DPM.
I think the best solution for your current issue with your data is to pre-process it in a service to output it so it will display properly.
