Binding a menu with an event
KishoreKumar1
Hi ,
I have a menu in my master and i have a button in my mashup.Clicking on the button should take me to the next menu item.How should i do this?
Thanks in advance,
Kishore
Hi @KishoreKumar1.
If we're understanding correctly, you can actually do this without a menu.  Instead, you can use the Navigation widget to advance to the next item.  This is a good solution if you're always advancing to the same mashup in a given sequence.
--Sharon
Hi @KishoreKumar1.
--Sharon
KishoreKumar1
(To:slangley)
Thanks,Using navigation is a good idea. I think I can use it in my mashup.
Just for exploration, Is there any way that I can bind a button to trigger the menu to toggle to the next menu option.
Kishore
Hi @KishoreKumar1.
If we're understanding your question, we don't know of a way to bind the button to the currently selected menu option for advancing to the next one.
Perhaps someone else in the community has an idea around this.
--Sharon
KishoreKumar1
(To:slangley)
Hi Sharon,
Thanks for the quick response. As of now I will mark your solution as an alternative solution as I didn't get the exact reply.
Kishore
