Hello everybody,
I am trying customize a label chart and to this I need to create some variables to bind to chart.
Below is a print with the TAGs (from my PLC) that I have bind with foundation (throught of industrial connectivity).
I wanna bind this TAGs into a InfoTable to after to bind in my chart.
I have created a data shape with two sources (Hour and value) and bind with my InfoTable, but I do not know how to insert the TAGs into this field in the infotable.
I used the guide that talking about create charts but the data are insert manualy in the field from data shape.
How do I do this?
Leonardo.
Hi @einsfele.
You indicated you wanted hour and value. Are you looking to return all historical values for each tag? If so, these will need to be logged to a stream. Once they're logged to a stream, your can run any of the various history services to return the values.
--Sharon
Hi @einsfele.
--Sharon
Hi @einsfele.
If my previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
If you're still having issues, please provide more details and we will try to assist.
--Sharon
