Blank screen is coming after login with Thingworx user on Form Login page of my organization
My user is part of user group and user group is a member of Organization
Home mashup of organization is already assigned with landing mashup and that mashup is being given the required permissions,
Application log is showing error Entity Not Found : [PlatformSubsystem] but platform subsystem is present in my Thingworx 9 environment
Thanks in advance.
Hi @ranjank
The error Entity Not Found : [PlatformSubsystem] indicates that your user has not visibility permission on PlatformSubsystem.
You will need to add the visibility permission to your organization on PlatformSubsystem.
See also https://www.ptc.com/en/support/article/CS227181
Hope this helps
Christophe
Hi @ranjank
Hope this helps
Christophe
