Border Radius to Modal Pop-ups
pshashipreetham
18-Opal
Is there any way to add Border Radius to the Modal Popups in the Thingworx 9.3
@c_lowy @CarlesColl @paic @slangley
Shashi.
Shashi Preetham,
+91 8099838001 | shashi@psptechhub.com,
PSPTechHub  ||  World of PTC Thingworx  ||  LinkedIn
You can use custom CSS in your Popup Mashup:
.mashup-popup, .mashup-popup .popup-mashup-goes-here {
border-radius: 50px !important;
7 REPLIES 7
@CGinus , don't think this is the correct CSS Syntax, "goes-here"  ?
Shashi.
Shashi Preetham,
It's a default class name so the CSS should work for any Mashup that's used as a pop-up, you don't need to change it in order for it to work.
@CGinus , can you pls tell me, what do you mean by goes-here ?
Shashi
Shashi Preetham,
It's just a name/class for the place where a Mashup is displayed when you use a pop-up.
Hi @CGinus ,
No clue what you are talking about, Thread is going bigger but no idea what does that syntax mean.
Shashi.
Shashi Preetham,
Tone
(To:pshashipreetham)
Hi Shashi,
the selector in this case is ".popup-mashup-goes-here".
You can also find it if you inspect and in the popup class it says "popup-mashup-goes-here", it is a fix name.
Best,
Antonia
