Bulk insert into database from CSV file
DK_9985660
3-Newcomer
Hi Team,
I want to insert  entire data from csv to Table using Bulk Insert, so that entire data from CSV goes to Table
by connecting one time to database , please suggest is there any option in PTC Thingworx
Datta
@DK_9985660 ,
Are you trying to store this in a ThingWorx storage entity (Stream or Datatable) or are you trying to insert these directly into a database via a SQL command?
If you're storing into a Stream or DataTable, you can use the AddStreamEntries or AddDataTableEntries service to insert in one operation.  If you're attempting to add into a database table, you can programmatically create your sql insert statement like:
INSERT INTO myTable (uid, label, value) VALUES
(1, 'label1', 'value1'),
(2, 'label2', 'value2'),
(3, 'label3', 'value3'),
Either way, you can use the CSV parser tools to first parse the CSV file into an infotable and then use one of the options above.
Hope that helps!
--Nick
@DK_9985660 ,
Hope that helps!
--Nick
slangley
(To:DK_9985660)
Hi @DK_9985660
If you found the previous response helpful, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
