Hi Folks,
I have multiple widget extensions to import and instead of doing multiple imports for all of them, I am looking to import them in a single shot.
Is there a way to bundle them as a single extension? heard of creating a metadata file for all extensions but don't know a way to achieve it.
TIA.
You can do it by simply bundling all the extensions into 1 zip. I don't think you would need any additional metadata. You can take reference from a marketplace/available on support.ptc.com extension like GitBackupExtension. It already takes multiple extension and import it as 1 zip.
Hi @TanmeyTWX
If the previous response was helpful, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
