Hi all,
There are 10 examples in the folder. Only three are tested.
DeliveryTruckClient, ExampleClient, SteamSensor.. What ExampleClient is? What is StreamSensor?
Run, but nothing is changed. And the rest do not even run.
Could you explain what the examples are about?
Thank you very much,
Hi Jeongeun Kim,
Did you download C SDK from PTC support website? https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=TWS
If so, which version did you downloaded, take an example of the latest C SDK version 1-5-2-1933, we could see there are totally 7 folders under the examples folder:
which do you mean 10 examples? Please explain a little more here.
Br,
Anna
