Thingworx Version: 9.2,
As per the Article: https://www.ptc.com/en/support/article/CS229450, done all the changes, but was not able to load the Dashboards. Gives following error:
Attached web.xml file too..
@c_lowy @slangley @paic
Shashi Preetham.
Hey hi @slangley ,
Thanks for the response, Tried the Article, that solved this issue, even though got so many issues after that, some how managed to solve them. Attaching the web.xml of the thingworx 9.2 version it may help someone in the future
Shashi
You can open a support "Case", here: https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
Hey hi @slangley ,
Shashi
Thanks for sharing this file with us!
