CORS issue with Thingworx and REST calls
Level 10
Hello everyone,
I am facing the famous CORS issue when making post calls from my java script to the Thingworx Server. To be specific, this is the error message: "...has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource."
I tried to add the CORS filter to the tomcat web.xml as described in this thread and I am still facing this problem. I am using the Trial-Version for Thingworx by the way.
Any ideas what could be the reason?
Any help is appreciated very much.
best Regards,
Dominik
4 REPLIES 4
Re: CORS issue with Thingworx and REST calls
Hello, Dominik:
   Is it possible you can share the fragment you added to the web.xml?
-Chris Kaminski
Highlighted
Hello, Dominik:
You can message it to me privately if you wish.
Regards, -Chris Kaminski
Hello @ckaminski ,
please excuse my late reply. Attached you can find the web.xml file.
Best Regards,
Dominik
  Sorry for the delay.  I assume you are not running Both CORS filter sections in the web.xml?
  Are you able to confirm the CORS header is not being sent with a tool like Postman or CURL?
-Chris
