Hi all,
Trying to configure new Windchill 11.2.1 Trace Management with remote Flow installation gives me error:
Access to XMLHttpRequest at 'https://flow.**/Thingworx/Things/OslcDataServicesThing/services/GetServerResourceDetails' from origin 'https://my.windchill.serv' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource.
How to configure it in NGNIX?
Take a look at this article https://www.ptc.com/en/support/article?n=CS248759
specifically how to configure Nginx directive to add header:
add_header Access-Control-Allow-Origin *;
You can also look here https://enable-cors.org/server_nginx.html for more info.
Hi Marek,
Thanks a lot for help!
Found answer in a Flow documentation also.
Unfortunately it turned out integration is not ready till ILM 12.3
Kind regards,
Andrey
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
