CSV Parser Help
SOLVED
Highlighted
Re: CSV Parser Help
I have used both way undefined and all column names too! is there any tutorials on this plz?
Highlighted
Re: CSV Parser Help
Have you imported CSV Parser?
Highlighted
Re: CSV Parser Help
No, I am still researching, Can you help me on this plz?
Highlighted
Re: CSV Parser Help
Yes, Thank Satish. Finally i have done it and imported successfully!
Regards
Vikas
Highlighted
Re: CSV Parser Help
Cool.
Highlighted
Re: CSV Parser Help
I have csv file imported, In csv file i have 5 columns like (timestamp, tagName, condition, timestamp_value, value) so
1524046971797.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524046975530.00 0
1524046972789.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524046976535.00 0
1524046973789.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524046977529.00 0
1524046974789.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524046978333.00 0
1524046974804.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524046979350.00 0
1524046975789.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524046980517.00 3
1524046976790.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524046981469.00 3
1524046976804.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524046982449.00 3
1524046977789.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524046983569.00 3
1524046978788.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524046984556.00 3
1524046979790.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524046985722.00 3
1524046980789.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524046986655.00
3
1524047070162.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524047093717.00 0
1524047071162.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524047094549.00 0
1524047072162.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524047095863.00 0
1524047073162.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524047096665.00 0
1524047074162.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524047097686.00 0
1524047075162.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524047098625.00 0
1524047091163.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524047116512.00 3
1524047092162.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524047117518.00 3
1524047093163.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524047118781.00 3
1524047094162.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524047119747.00 3
1524047095162.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524047120609.00 3
1524047096162.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524047121857.00 3
1524047097163.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524047122868.00 3
1524047098163.00 Channel2.ARK CNC Machine.General Status Information.Auto Operate TRUE 1524047123886.00 3
few rows are coming with value 0 and then 3 and again 0 respectively....
I want to calculate summasation of timestamp with intervals which has value 3
is there any way to calculate such values or can you give me any idea so that i can try?
Regards
Vikas
Highlighted
Re: CSV Parser Help
Filter with value 3. and iterate the infotable or do aggregation based on requirements.
Highlighted
Re: CSV Parser Help
Hi Satish,
Can you help to do "Filter with value 3. and iterate the infotable or do aggregation"?
I am really new to Thingworx, can you plz?
Regards
Vikas
Highlighted
Re: CSV Parser Help
Hi Jeff,
Here is an example per the test data you provided and it works on my Thingworx 7.0.0-b479:
var params = {
    columnMappings: "Tagname;Description" /* STRING */,
    hasHeader: "false" /* BOOLEAN */,
    longitudeField: undefined /* NUMBER */,
    dateFormat: undefined /* STRING */,
    latitudeField: undefined /* NUMBER */,
    fieldDelimiter: "," /* STRING */,
    stringDelimiter: "\"" /* STRING */,
    content: "XV101,Valve Input\n" /* STRING */,
    dataShape: "PES_Tags" /* DATASHAPENAME */
// result: INFOTABLE
var result = Resources["CSVParserFunctions"].ParseCSVFile(params);
Hope this helps,
Br,
Anna
Highlighted
Re: CSV Parser Help
Thanks both of you!!!! My issue was the space between the columnMappings... I appreciate it.
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
