The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Hi all.
I think it is a widget error.
When mashup opened, It occurs error message that '"xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx" opened with error(s).'
Can I know the widget which occurs error from the error code?
then, How can I know the widget?
Thank you.
Hello, Kiyong Park.
Typically we'd look through the application log to get some context and then try to pinpoint the cause of the error. If you can comfortably attach the log we can take a look through it. Also perhaps a screenshot of the mashup.
-- Craig A.
Hello, Kiyong Park.
-- Craig A.
Hello, Craig Arko.
I solved this problem from f12(Developer Tools).
Thank you for your pleasure.
-kiyong
