Can We configure variables globally in Thingworx Composer
sdaram
Hi , Can we configure variables in thingworx globally. Something like How we are Maintaining WEB.CONFIG file in .NET. In My Scenario I want to configure a variable where i need to set refresh rate of page (SCREENREFRATE='5' min). In later point of time if i want to change SCREENREFRATE from 5 min to 10 min .I need to easily change the value Do we have this kind of settings in Thingworx Composer. please let us know Thanks & Regards Spandhana
5 REPLIES 5
ankigupta
(To:sdaram)
Hi spandana daram​,
I suppose that this can be achieved by creating a Thing and saving these information as persistent properties.
Then use it wherever you want.
Hi Ankit,I am facing the same issue. Could you please explain in detail?
Hi Bavithraa Marimuthu​,
Could you please explain your usecase in detail?
supandey
(To:sdaram)
Spandana, have you already tried the option of setting the Session Parameters? You can customize the session parameter by adding your custom thing shapes and once you have it there you could reference anywhere in the composer.
Or have i got your use case wrong?
ankigupta
(To:sdaram)
Hi spandana daram​,
If the Global Parameters are common for all users then Creating a Thing with Persistent Properties can be used.
If the Global Parameters can have different values for different users then Session Parameters as suggested by Sushant Pandey can be used.
