Hi, I'm new to ThingWorx and in general an IT newbie.
I installed the 120 day Trial Edition 8.2 on Windows 7 Enterprise SP 1.
Also installed Docker/Oracle Virtual Box.
Yesterday completed the installation, but now I can't accsess the Composer via http://192.168.99.100:8080/Thingworx/Composer/ anymore.
It says "ERR_CONNECTION_REFUSED".
DockerMachinePTC running well in Virtual Box
Hope, you can help me.
Regards
nairobi
Hi, @nairobi22,
Have you started a Tomcat service? Could you please check the Tomcat / ThingWorx logs? You can find them in the directory where Trial version of ThingWorx is installed.
BR,
JK.
So today the Composer works again... :D
I will try to sum up my problems:
First I installed Docker as pre requirement, and than started the installation of the ThingWorx Trial Version.
A DockerMachinePTC was created in Oracle Virtual Box.
After all of that the Composer worked, but i couldn't start the VM DockerMachinePTC out of the Virtual Box Manager [Code: Callee RC: E_FAIL (0x80004005)]
Yesterday I could start the DockerMachinePTC normally but could not access the Composer.
Now I can access the Composer again, but can't start the DockerMachine :D
Between all of that I don't remember changed anything on purpose.
I don't remember anything related to Tomcat during the installation or as a requirement, is that an alternative to Docker or comes Tomcat with the Trial Version?
Attached the install.log, maybe that helps
Hello again.
So after a couple of days, where I could access the Composer without problems, but still couldn't start
the DockerMachinePTC via VirtualBox (assuming it has to run for Composer, but doesn't show it), now I can't accsess neither Composer nor the VM.
I reinstalled everything, log files attached, but still have the same problems.
Hope, you can help me with this.
Best regards,
Nairobi
