I was testing a service I wrote to allow users to create users using the CloneUserWithGroups() API. When testing, I created a couple users while logged in as the Administrator. That part worked fine. My issue is: ThingWorx won't allow me to delete those users!!??
ThingWorx returned a Delete Failure error message saying, "Editable System Objects Cannot Be Deleted."
I've removed those users from the groups the Administrator is in, but I'm still getting the same error message.
Alright, just looked into the details of the one I reproduced.
Because you clone an Administrator user, it writes it as a systemobject (cloning all aspects).
I exported the user entity in xml format and manually edited the
aspect,isEditableSystemObject="false" (was set to true originally post creation)
Save the xml, import it back into the system- now you can delete your user.
Hi @Timo697.
Can you provide a screenshot of what you're attempting to delete? Based on the error message you're getting, it sounds as if you are deleting system objects instead of the users you created.
Regards.
--Sharon
In the old composer, I'm still getting the same fail to delete message.
Hi @Timo697.
Have changes been made to the Administrator account in regard to locale? I found an internal case regarding localization that could possibly result in this error.
Please provide details so I can attempt to recreate the issue.
Regards.
--Sharon
I'm not entirely certain what you mean by locale, but the Languages field is "en". I recreated the error just now. And without doing anything to the Administrator fields, I couldn't delete the new user made. Below is the coding I used to create a user.
var params = { password: New_Password /* STRING */, sourceUserName: Existing_Username /* USERNAME */, name: New_Username /* STRING */, description: undefined /* STRING */, tags: undefined /* TAGS */ }; // no return Resources["EntityServices"].CloneUserWithGroups(params);
Users[New_Username].Access_Level = New_Access_Level;
Users[New_Username].emailAddress = New_Email;
Users[New_Username].firstName = New_First_Name;
Users[New_Username].lastName = New_Last_Name;
Something else to consider, I'm running this on a trial version of Thingworx 8.3 (the company I work for is going through the process of purchasing it though).
I was able to reproduce the issue. What access level did you set up as your input? It seems like the users were created as system objects.
Thanks posipova. That worked.
I think this issue needs to be documented or corrected in the cloneuserwithgroups api. I've read documentation that the Administrator can delete a user even if assigned to the administrator group.
