I am very new to this platform, this field itself. I want to get data from IP21 to Thinworx. Is it possible? If so then how can we fetch the data from IP21 to Thingworx?
Hi @equinoxss are you referring to the Aspec Tech IP21? are you looking to use the JDBC or ODBC to connect to the ThingWorx? There is a JDBC Connector available that could help you get the connection going.
If you are looking to work with the ODBC driver you can check the ThingWorx Edge ADO Service
Hope this helps.
Did you have any luck connecting to a AspenTech IP 21 Historian? I am currently trying to accomplish the same thing, but not having any luck?
