Can we insert widgets or other mashups into grid ?
apodupuganti-2
I want to display status bar in the grid. can we do that..?  if it is not possible with widgets or mashups... is there any other way ?
Hi Akhila, could you elaborate a bit more on your use case? If I understand it right you'd like to have Grid and a Status bar shown as a single entity on the mashup, won't it be easier to do it with Gadgets? In a Gadget (which is essentially mashup of pre-defined size and columns ) you can have both Grid and status message widgets together.
I don't think you can edit the OOTB Grid.
In my case the grid is used to display information of different printers and its ink statuses. So in each row I want to represent the ink status in loading bar (here Im using shape filling widget).  Why I wanted to do this way is because there will be thousands of printers. I cannot display each printers information separately.
You must use a Repeater Widget, then you can put anything you want on each row.
Related image
Sorry Im new to thingworx. Can u please explain how can we do it ?
I want status bar to be displayed in grid like shown in this picture.
Again with the Repeater Widget, basically Repeater Widget it's a Table of Mashups, then on each row you have repeated Inner Mashup .
