Can we install Analytics server on host machine of Thingworx 8.
Thingworx 8 is hosted on windows server 2012 R2 maachine .
Which version of docker will work with this windows OS.
Does it creates any impact for other components like dataconnect which has to be installed with Analytics server?
Raji
Hi Raji
Apologies for the delay I was OOTO.
ThingWorx Analytics 8.0 is not currently supported with Windows 2012.
Windows 2012 is planned to be supported with ThingWorx Analytics 8.1 (which should be out end of September)
Kind rgeards
Christophe
Can you please help with these queries.
if we can install both on same machine, I can go with docker version of 17.03.0-ce right ?
In installation guide of Analytics mentioned that
"Install the appropriate version of Docker for your operating system before installing the ThingWorx Analytics Server. On the Install Docker Engine site, find the installation instructions for your host operating system and follow them to install Docker version 17.03.0-ce or later."
As I mentioned in my query my OS is windows server 2012 R2.
Raji.
Hi Raji
Kind rgeards
Christophe
Hi Christophe,
Thank you very much for clearing my query.
So Thingworx8 is compatible with TWX analytics 8.1 or we have to upgrade Thingworx also?
Raji
Hi Raji
I do not have any information at this stage about the compatibility matrix of release 8.1, so I cannot tell you if you would need or not to update ThingWorx platform too.
Thank you
Kind rgeards
Christophe
Thanku Christophe for your response.
Thingworx Analytics 8.1 is released now.
I hope it supports with Windows 2012 server .
Can you provide installation document for reference
Hi Raji
The documentation can always be find in the Reference Document page: https://support.ptc.com/appserver/cs/doc/refdoc.jsp?p=browse_results&Product=ThingWorx+Analytics&Release=8.1&DocType=
You may also want to check the Help Center: PTC
Regarding the support of Windows 2012, there is unfortunately no official support at this time .
It is expected to work but it had not be possible to QA this OS, so it is not officially supported.
You can see the supported OS in the ThingWorx Analytics Server docker installation guide: https://support.ptc.com/WCMS/files/173637/en/ThingWorx-Analytics-Docker-Installation-Guide-8-1.pdf
Kind regards
Christophe
