Can we make widgets using angular 8 ?
SK_9454947
I want to use angular 8 for making my widgets, how to do that ?
1 ACCEPTED SOLUTION
I can't specifically help in this area, and neither have an example, you need to transpile your TS to JS and embed it as a widget.
If you need help in this area there are some partners that can help for a specific thing like this. Please contact your Partner Manager or Customer Success Manager and mention this thread, so we can obtain the appropriate support.
There is an existing post regarding creating widgets in Angular, I presume you are already aware of this and you're asking specifically for Angular version 8?
Yes, That process is cumbersome and it uses Angular JS which I am not comfortable. Actually I have made a drag and drop feature in  Angular 8 and want to deploy it in TWX,  can you help?
