I'm having an issue adding a subscription to my Thing Template. It won't allow me to select the "Other entity" option to pull in the correct entity and specify the event type:
I've seen some other post similar to this. Wondering if I need to clean out some corrupted files or something. Any help on this would be great.
Reginald
Could you please Provide some more details on below points:
1) Are you not able to select the radio button because I have checked the same at my end and I am able to add other entity in new subscription.
2) Did you check application logs, is there any error or In case you can provide application logs to us.
I was able to see the radio button, but I just could not change it. Turns out there was a new ThingWorx version that resolved this. Once I updated, it started working.
This issue can be closed
